→ Аккумуляторы
+971523310870 Abortion Pills in Sharjah /Dubai MANAMA (Bharain) Mifepristone & misoprostol in Abu Dhabi/Alain/ sharjah/ Albasha / Deirah Cytotec Available in Dubai/Abu Dhabi-ipills in Dubai Buy Abortion pills in UAE & Abu Dhabi BUY Abortion pills Dubai ( б/у
12 июня 2026 в 20:44
bencarson.com
bencarson.com
Аккумуляторы
24 грн
05XXXXX Показать Написать продавцу
Сейчас размещает 432 объявления
Зарегистрирован 10 июня 2026 года (40 дней 14 часов назад)
+971523310870 Abortion Pills in Sharjah /Dubai MANAMA (Bharain) Mifepristone & misoprostol in Abu Dhabi/Alain/ sharjah/ Albasha / Deirah Cytotec Available in Dubai/Abu Dhabi-ipills in Dubai Buy Abortion pills in UAE & Abu Dhabi BUY Abortion pills Dubai (+971523310870) Cytotec pills in Abu Dhabi- (in UAE)
(+971523310870) Abortion pill / Cytotec 200mcg (Misoprostol), Mifepristone, Mifegest-kit, Misoclear, Emergency contraceptive pills, Morning after sex pills, ipills, pills to prevent pregnancy 72 hours after sex is when you take medicines that you get from a trained doctor to end an early pregnancy. In clinic, abortion is done in a health center by a trained doctor. Both kinds of abortion are safe and effective.
Ending a pregnancy /pregnancy termination “abortion” is a common decision that millions of people in Dubai / UAE make every year. Half of pregnancies in Dubai end in abortion and this are all with the help of Dr. Mrs.Linda who has provided the best abortion services within all Gulf countries like UAE / Dubai, Qatar / Doha, Kuwait, Saudi Arabia and all neibouring countries. Don’t be stuck with unwanted pregnancy, Whatsapp +971523310870for your 24hrs services plus free delivery.
And regardless of whether abortion is legal or not, people still require and regularly access abortion services because it’s one’s body so they free to have the child or not therefore don’t be scared to standup for your rights. Reach us on our 24hr helpline +971523310870
COMMON QUESTIONS AND ANSWERS ABOUT ABORTION.
1. How do abortion pills work?
You take pills” Cytotec 200mcg (Misoprostol), Mifepristone, Mifegest-kit, Misoclear” that end your pregnancy and make your uterus expel the pregnancy tissue within 24hrs.
2. How effective do abortion pills work?
If you follow the right steps as advised by Dr. Mrs.Linda and take the right pills then we assure you that the abortion procedure will work more than 99% of the time.
Pregnancies from 0 to 12 weeks use cytotec 200mcg is the best pills.
In this case, one needs to acquire five (5) pills of cytotec (the dosage may differ depending on one’s body weight, mostly people with weight above 70 kg may require more than 5 pills depending).
Place all the 5 tablets of misoprostol (cytotec 200mcg) under the tongue and allow them to dissolve for 30 minutes then swallow what’s remaining in the mouth with very little water to rinse through the mouth and swallow. If one’s weight is 70kg or below, then expect to bleed within a period of three (3) hrs. In some females the bleeding and cramping might take longer to happen but it shouldn’t exceed 48 hours and if so please contact our 24hr helpline on +971523310870Whatsapp.
For pregnancies within 12 weeks, Dr. Mrs.Linda recommends the use of mifepristone which is combined with misoprostol to bring about an abortion during pregnancy. It is also effective during the second trimester of pregnancy. Effectiveness should be verified in 2 weeks after use.
Mifepristone is anti-progesterone which works by blocking the effect of progesterone making the cervix easier to open and promoting contraction of the uterus when exposed to misoprostol.
You will take 2 sets of pills for your abortion to be effective. The pills you will take on day one (1) are mifepristone. Mifepristone is taken through the mouth by swallowing like any normal pills, after swallowing the one mifepristone pill, wait for 24 hours before you use the other set of pills misoprostol, usually four pills. Put the 4 misoprostol pills under your tongue and wait till they dissolve before you swallow.
For one to tell that an abortion has been successful, one should experience bleeding through the vagina. The bleeding varies in individuals, some individuals bleed for a much longer duration than others but its all normal.
3. How long does the abortion process take?
This is a 10 minutes procedure, but the full visit usually takes a few hours. In some cases, state law requires you to come to the health center for a separate visit before the abortion. Abortions later in pregnancy may take longer and require more visits to the health center.
Your appointment with Dr. Mrs.Linda will take a few hours, and then she’ll give you the pills. You take 2 different medicines, up to 2 days apart. You may take both of the medicines at home. Or you may take one or both of them at the health center. Most of the time the abortion is over within 24 hours after you takes the second set of pills. You’ll have a follow up by reaching her on her 24hr whatsapp helpline +971523310870to make sure the pills worked.
4. How safe is abortion?
Medical abortion has low complication rates. It’s been approved for more than 20 years and has been studied in more than 100 research medicine institutes worldwide and it’s concluded that it is both effective and safe which concludes that it’s less risky than any other means of terminating a pregnancy. Therefore do not hesitate to contact Dr.Mrs.Linda on her 24hrs Whatsapp helpline +971523310870
5. How will I feel after having an Abortion?
According to our research and long term experience, a number of people claim to feel fine within two to five days. It’s common for bleeding to last for a week (or several weeks after the abortion process). Cramping can happen for a few days.
It’s totally normal to have a lot of different emotions after your abortion. Everyone’s experience is different, and there’s no “right” or “wrong” way to feel. Most people are relieved and don’t regret their decision. Others may feel sadness, guilt, or regret after an abortion. Lots of people have all these feelings at different times. These feelings aren’t unique to having an abortion. People feel many different emotions after giving birth, too.
Requirements (items) To Carry out an Abortion in UAE | DUBAI | ABUDHABI | KUWAIT | QATAR & SAUDI ARABIA
1. Abortion pills as prescribed by a professional doctor
2. Non-steroidal anti-inflammatory (NSAID) pain medications like ibuprofen.
3. Sanitary towels / pads
4. Clean water
5. It is important to have somebody accompany you during a self-managed abortion, especially for abortions after 12 weeks
SURGICAL ABORTION IN UAE
Bring back lost love spells +27783488291 in,Savannah ,Bridgeport ,Torrance, McAllen ,Syracuse,Alberton,Boksburg,Edenvale,Germiston,Randburg 2000 грн
15 июля 2026 в 12:59
Аккумуляторы .HOW TO CAST DEATH SPELL+256759162994?((THAILAND) )QUICKIEST FASTER death spell casters URGENT INSTANT DEATH SPELLS IN SOUTH AFRICA UK USA SPAIN ITALY CANADA UAE MALTA BRUNEI JAPAN,IRELAND TURKEY LUXEMBOURG ICELAND,NORWAY 250 грн
11 июля 2026 в 11:54
Аккумуляторы $$ 256759162994 @@POWERFUL BLACK MAGIC INSTANT REVENGE SPELL CASTER IN UGANDA, NETHERLANDS, SPAIN, SCOTLAND 250 грн
11 июля 2026 в 11:53
Аккумуляторы +256759162994. Voodoo Magic love spells caster in France, Philadelphia, Boston, Brooklyn, Ayamelum. 250 грн
11 июля 2026 в 11:50
DXB-UAE +971523310870# حبوب الإجهاض للبيع في البحرين مدينة حمد، الرفاع، المنامة، والجفير. تتوفر الخدمات أيضًا في أم القيوين والفجيرة وعجمان ورأس الخيمة وأبو ظبي والشارقة والعين وخورفكان ودبا. +971523310870) تتوفر مجموعات الميفيبريستون والميزوبروستول للإجه
24 грн
24 грн
Все 432 объявления
